Rally style Sill Stands?
JasonBird
I have. I couldn't find any really good pictures of them but many not so good.
Look my blog here:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,269120/postdays,0/postorder,asc/topic_view,/start,0/
Don't worry about balance. Put them as much to front and as much to rear where you can mount the tubes securely.
Tommy
I can't get better pics now while the racer is stored away, but I can explain.
First I cut the tubes and made holes through both outer and inner rocker panels. Then I made a plate 3mm thick about 2x3" for the inside. The tube was welded to this inner plate and then put into place from inside. Plate was then welded. Then I made outer plate with hole for the tube. It's about 3.5x3.5", welded to rocker and the tube. Very sturdy construction. Pay attention that they all are on same level and the tubes are horizontally positioned.
My stands have slight angle over 90 degrees between the pin and base parts. It makes them stand more stabile. Very handy for a racercar.
hth, Tommy
So what if your work shop floor is less than perfect? Problem in terms of leveling the car?
Pete
Well mine is a good example of that. I have different thickness plywood "shim plates" that I use under the stands.
Tommy
