Sign in to follow this
JohnN
M20B25 Engine ---- SOLD
5 posts / 1211 viewsLast Reply
Hey folks,
This was pulled from a 1989 325i and had about 130,000 on it.
I was building a dedicated track car, but have too many projects and insufficient time to complete the work. When the engine
was out, I replaced the timing belt, water pump, injectors, rear main seal, pilot bearing and replaced the headbolts with the later
"stretch" style. I also cleaned up the engine and painted it a nice gloss black with high temperature engine paint
The engine now has a VDO oil pressure sender (gauge+idiot light) and oil temperature sender.
This engine has a throttle body modified for use with a MegaSquirt (TPS and intake air temperaure).
I just ran a compression test, cold engine (as in stone cold). Exhaust manifold in place, all spark plugs removed, throttle body open.
#1 ----> #6
165, 150, 160, 150, 165, 160
I'd prefer not to ship, but I could probably put this on a palate and ship via Freight.
$550 obo, located near Portland, OR.
Thanks!!
John N
No wiring harness since I stripped everything out that wasn't needed for a MegaSquirt. Otherwise everything from the flywheel forward.
If you're going to go Motronics, you'll need an AFM, a new throttle body and all the wiring bits.
I also replaced one of the water temp sensors (IIRC it was open/closed on the M20) with one that gave the MegaSquirt the coolant temp.
Drop me an email john dot nevius at gmail dot com
John N
