Hutton
Penetrating lube WURTH2000
9 posts / 1183 viewsLast Reply
Anybody know where I can find WURTH2000 penetrating oil/ lube. Or recommend another product?
Need to clean and lube the tii linkage and pedal spring....The car was last
registered in 1999..he he...
Spent the day working on the car..
*tii calipers re-built installed lines bled
*clutch slave cylinder bled and working
*tii K-pump adjusted
*new motor mount installed. ....Cleaned up the interior.
Oh, still need to install the recaros and Nardi wheel....Running
BWA wheels
Chris
Try an on-line search or some better Euro repair shops may use it and will sell you a can.
It is good stuff, sprays on like an oil and sets up like a light grease.
Well penetrants and lubricants are two different things.
My fav penetrant is pb Blaster
If you're looking for the Wurth Lubricant: Wurth2000
If planning a lot of projects/restoration, I'd suggest both.
Cheers!
the correct name is HHS2000 that stuff is not that great when i worked at the dealer the parts dept use to give that stuff away, FYI its about $15 a can.
Kroil oil---if you can find it--usually gunsmiths have it---lots of snake oils out there---this stuff works great to free up frozen parts---scoyote
Cheers!
although the best in my opinion, pb blaster does not associate with germany nor does it cost 9 times the price of the hoity-toity stuff
i'm a firm believer that people should be able to waste their money on whatever they want to
Wurth2000..WOW this is great stuff....Picked up a can for 5 bucks from a local shop ......The can probably retails for more.
Used the stuff on my tii likage and pedal springs
C
