Brandon73fjord
Compression test. Acceptable range?
6 posts / 1445 viewsLast Reply
I'm having my engine compression tested. My mechanic wants to k ow what's acceptable for this type of engine. I'm askink for a range in numbers(120-160). Thanks
140done correctly on my tii
Consistency within 5% hole to hole is ideal, with 120 to 160 net acceptable as gauges and operators very.
valves adjusted cold (0.006")
battery fully charged
hold throttle wide open while cranking
have all plugs removed
compression test 1502 - 2002tii
good = above 10.5 bar (149.3 lb/in)
normal = 9.5 bar (135.1...149.3 lb/in)
poor = below 9.0 bar (128 lb/in) = you need work
test procedure
use calibrated tester,
with battery fully charged,
engine at operating temperature
and throttle fully open.
Turn engine over at starting speed.
I guess I know why I have to run super...
172psi on the motor built by BC & Me.
BD
engine that came out of my 75... 100 plus or minus 20psi.
engine that went in.....180 plus or minus 2psi
cd's got the correct info, of course, for a stock engine. cam/piston/ring/crank whatever upgrade will cause variance from stock numbers.
