Do urethane endlinks use the same bolt ?
Codfish
It all depends in which urethane bushings you have there. Some are designed as direct fit with 8mm holes through them etc... while others have big American holes.... and are too tall to fit the stock length bolt. I have brought a bolt and rubber bushing setup to the parts store and asked for either bushings to fit or a complete bushing/bolt/washer kit that'll work.
I also agree with Jim that it can be difficult to install the front end link bushings while the suspension is at full droop. You want to snug them down while the suspension is loaded anyway.
HTH
Tom Jones
and a trick for installing the end links with the car on stands...put a jack under the end of the control arm and gently jack it up to compress the suspension spring. Then you can get the nut on the end link bolt without a lot of trauma or having to contort yourself under the car while it's on the ground...
The stock ones connect fine...Now I have come to the conclusion that I will need longer bolts...
As per the manual etc., you have the "cup" washers upside down.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Thank you... That was clearly my mistake, the urethane fit fine.
Picture worth a 1000 words huh...
Time is the ruler of all...
