Sign in to follow this
pyite20v
Can anyone translate this german build sheet?
5 posts / 1139 viewsLast Reply
I got this with my craigslist engine, and hopefully it tells me whats in it.
Ventil reinigen und uberschleifen
Ventilfuhrung BMW 318
Ventilfuhrung wechsein
Ventilfuhrung aus und einbauen ggf.
Ventil einpassen
Kopf planenschleifen bis 600mm
Ventilsitz mit 3 Winkelfraser nachfrasen Schaftabdichtung + Ventil montieren
Kanale + Ubergange leistungssteifernd beabeiten
Nockenwelle einpassen + Ventile einstellen
Phew, any ideas?
Here is what Google Translate came up with. So I am thinking this is just for the E21 head I have on it.
And clean it uberschleifen
Ventilfuhrung out and insert if necessary
Fit Valve
Head plan grind up to 600mm
With 3 angle valve seat Fraser nachfrasen shaft-mounted + valve
Canal + transitions adaptation entitled leistungssteifernd
Fit + set camshaft, valves
Anything of interest in there?
Ventil einpassen
Phew, any ideas?
Cleaning valve and polishing ?
Valve guide Bmw 318
Valve guide ?
Valve guide dissamble and assemble
Valve adjusting
Cilinderhead flatting
Fixing valve seats + mounting valve & seals
Flowing the exhaust/inlet channels
Adjusting camshaft + valves
Ventil einpassen
Phew, any ideas?
Valve guide Bmw 318
Valve guide ?
Valve adjusting
Clean the valve and
Clean the valve, not exactly sure what uberschleifen means, schleifen means to cut and uber means over, you're probably supposed to clean and lap the part that contacts the valve seat
valve guide
change the valve guide
R&R the valve guide if necessary
Ventil einpassen
(test) fit the valve
plane the head to 600mm (although that's not really a feasible amount, because you'll have to add height)
Cut the valve seat with a 3 angle cutter and mount the valve seal and valve
Flowing intake and exhaust channels and transitions between the manifolds (leistungssteigerend basically means raising the power output)
Mount the camshaft and adjust the valve clearance
Phew, any ideas?
That's the best I could come up with.
