ClayW
Timing Cover Bolt Map
4 posts / 1024 viewsLast Reply
Does anyone have a map or reference for proper timing cover bolt sizes, pitches on placement? It would be nice if there was a reference somewhere permanently on the board.
If anyone else is like me, you're probably mixed them up......which leads you to wonder if misplaced and wrong-sized bolts are the reason for your continually leaky timing cover.
Real Oem has the lengths, but they don't give the pitches.
Real OEM and other sites have some of the info, but I'd like to get a good reference going. I need help filling in the blanks.
*#17 is for all four fan bolts.
Thanks in advance!
It shows:
#5 M8x35 (3 used)
#10 M6x28 (3 used)
#14 M8x90 (3 used)
Other bolts sizes are referenced, but without a good diagram of where they fit.
Upper case M6x35 (9 used - horizontal) & M6x25 (2 used - vertical at lower edge)
Lower cover M6x40 (1), M6x35 (9)
