A New model ---
jimk
Distributor Cap?
Remote oil level readout?
Tachometer sensor?
High Intensity starter motor?
Electronic gadget to make the driver happy?
Distributor Cap?
Tachometer sensor?
Hmmmm....it's clearly made from a distributor. Cam position sensor?
Where did you get the picture?
ClayW
Cam trigger. The secrets are within. Took the pict this morning - my car. Just a teaser for the wannabe full sequential MS crowd.
My guess is that it somehow involves the Honeywell GT101 hall sensor. Crank/cam sensor?
Very good.
I worked up an alternate first off using a Honeywell SR13D-A1 that is no bigger than a quarter and costs less than $7. Went on to ust the GT101, I had it anyway and knew it worked, but costs 3x as much.
There ain't much inside but the bottom of a rotor with one advance stop left and bent in a bit for a tooth.
Very good.
Please, More details!!
I have been toying with the idea of a coil on plug set up, but electrical components aren't my forte.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
you could have used this type too, cheaper altough i am not sure if the maximum switching speed could be suited for such application. Cost like 2$ normaly.
1985 XR4TI, 22psi ±300hp
Pat, that looks like a VR sensor which isn't as reliable for a cam sensor. Too much time between pulses and too small a pulse voltage at idle speeds. ECM mfrs are recommending VR sensors for crank where there are many pulses even at low rpm and with high pulse voltage.
