Quick exhuast question
Hamburgers
Are the studs that connect the exhaust manifold to the downpipe the same studs that connect the manifold to the head? I haven't been able to find "down pipe studs" anywhere on the internet, and figured it's because they're the same as head studs.
The car has become a secular sanctuary for the individual, his shrine to the self, his mobile Walden Pond. ~Edward McDonagh
07 11 9 909 117 is 10x1.5 thread 25mm long and the original '02 #
11 62 1 711 671 are 35mm....
11 62 1 716 870 are 40mm...
I like the 35mm ones.....
Also only use the copper exhaust nuts... I like the 15mm wrench size pinch ones rather than the cheap 14mm head ones. # 18 30 1 737 774
http://www.autohausaz.com/search/product.aspx?sid=forr1k55jnlpav20cyqwql55&partnumber=18301737774
The cheap ones can bind and strip threads when removed!
Oh, and use good copper anti seize on all exhaust threads!
Tom Jones
Ah, I have also seen warped downpipe flanges that will not seal up no mater how many times one replaces the gasket and nuts.....
I suggest placing a straight edge on said flange once off to check for flatness. If not flat..... easiest way to fix it is to replace it.
Tom Jones
