Which tires 195/50/15s have a rolled outer edge?
dp2002
I am looking to put some 15X7.5 wheels on my car and according to search results, I need tires with a rolled outer edge?
My questions are 1. which tires have this? Which Falken, which Toyo, etc? Are there any for around $55-65 online? That are good enough you would use them?
Thanks for the help
1971 BMW 2002-Chamonix
http://whitey02.blogspot.com
According to Robspeed, if I run the Ronal ls wheels I need a tire with a rolled outer edge. I am not sure how you can tell, does the description on the internet tell you? Falken 512 tires have this rolled outer edge and Kuhmo do not. I would like 5-7 different choices of tires that I can use with the Ronal ls and non-flared 71 2002.
Do bf goodrich g force sport have a rolled outer edge?
Thanks
Falkens run narrow and have a radius shoulder.
Looks like Bridgestone ER30's and the Sumitomo 200 has a narrower overall width(7.7")
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
hey dp,
i've got 15x7's w/ an offset in the mid 20's and running bridgestone's re01's in 195/50/15. suspension consists of bilstein sports and IE stage1 w/ 1 coil cut up front. i'm getting slight rubbing on the outer edge of the tire where it is contacting the fender so will need to roll the fender a little bit. i guess the re01's have a more squared off sidewall rather than a rounded sidewall design...
fred
my project blog:
craaaazzy's 2002 project
