Pre-loading question
nbristow01
OK, I read my old post. A gentleman says that you do not pre-load the guibo but you do preload the center support. How do you pre-load the center support? I had planned on mounting the shaft to the guibo, then mounting the shaft to the diff, then mounting the center suport...is this the correct sequence
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
you just bolt everythign up, and then slide the center support forward 2mm before snugging it down. Or up.
There's a CD pic for this one...
...yes - bolt up the guibo front, and rear diff joints first,
make sure the whole mess looks straight, meaning the guibo
does not 'flex' out of a straight line when rotated, and the final
tweek is 'preload' the center bearing rubber mount by sliding it
forward 2 ..3 mm and then tighten it up
another note never mentioned here is the importance
of the centering bushing inside the guibo end of the drive shaft
if yours is missing, chewed up, melted, your going to
continue chasing vibrations, and replacing guibos - pack
it with high temp moly-grease ( A ) as the diagram shows
'64 R27 250cc #383851 18,000m
