Yes, Again...Heater valve
madpaddler
I know this has been beaten to death, but I still cannot figure if I am missing something. I have searched the many valve topics, but cannot figure out what I am missing. My valve was completely frozen up and if there were any O-rings in there at one time they were dust when I finally got the thing apart.
In the pic below item #1, if you actuate the valve, there is play (about 1/32) in and out. You might see in the photo #2 inside the valve that the opening can move in and out. In the second pic I took the back off and showing what I thought I needed to refurbish the part. I replaced the O-ring that you see that fits that larger grove and the smaller one on the other side of the valve (you cannot see). In photo #3 there seems to be something missing that should go in the center hole maybe to push the valve inside so it keeps the innerds pushed in all the time. #4 just shows the lip that provides the space for movement. Is there a spring or nylon grommet that is suppose to ride in that "hole?"
Spent a lot of time messing with this and want to be sure it is right before reinstalling the heater box...an help?? Been driving with no heat for a couple weeks, its getting old!
'76 2002 A "camo blue"
'73 2002 A Chamonix
'71 Airstream Globetrotter
'72 2002 A Verona-crashed then stolen
2007 Toyota FJ
Test the valve now before you install with a couple of hoses and a water source. i have yet to mess with my heater box so i cant really address issue directly.
Just my 02cents! have fun
typical Radiator pressure is about 10-13 psi if i recall.
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
On my '74 heater valve(I bought a complete heater box and the valve came with the box), all that needed to be replaced were the 2 O-rings. My valve was brass, but the cover didn't have the "arrow" on it like yours shown. The insides (where yours looks like there may have been a bushing/or spring) was slightly different (it had "bumps' in both the centers) and there was nothing(bushing/spring) in the centers of the peices.
Mine had what looked to be original flat bladed screws in it and didnt look to have been taken apart before. I think there was very minimal side to side play when it was put together, but it worked fine and passed a pressure check and has been working great since installed.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
I'm pretty sure it won't pass a leak test as I can see a hairline of space on the small O-ring side of the valve. Anyone have a good valve they can look at taking apart to see all the bits that are suppose to be there? When I took this one apart, there were only fragments of the rings and bits, nothing identifiable. It does need to be the same valve as I have seen a couple different kinds with and without arrows.
'73 2002 A Chamonix
2007 Toyota FJ
