carbs got the dribbles
nbristow01
Wel back in my holley 4bbl days when I would throttle by hand, engine not running, the fuel would spray in the primaries then when it went into secondaries it would spray those too.
My weber just kind of dribbles the fuel out on the primary and on secondary you get very very little, just runs down the inside....also the primary diaphram pump is wet on the outside, indicating a gasket leak
When these carbs are in proper order does the fuel come out with a bit of force or just kind of dribble out?
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
Uhhh, you mean when you open the throttle plates with the
motor running?
You don't see a fantastic pattern, really, because it's hard to get enough
airflow without a dyno to load it up on.
If the motor's not running, however, fix your float/float level/float valve-
no fuel should come from anywhere but the accel pump when you're not running.
