Reason for slow rev found
nbristow01
Well duh on me, I am so used to electronic ign I never even looked at the vacuum advance on my car. Its not even hokked up!!!!!!!!!!!! No hose, nothing...ok, so I get some hose tomorrow. It goes from the dist to????
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
It goes to the vacuum nipple that comes off the side of your 32/36 ABOVE the throttle plate (butterfly). As long as the advancer works you should feel a significant improvement. Sometimes the hose has been removed and carb nipple plugged to eliminate a vacuum leak from a failed / ruptured advancer diaphragm. You probably will still need to check / adjust your timing. You'll definitely have to tweak it when you install Pertronix / MSD. And be sure to do ALL the above before you even THINK about installing you dual carb setup. You need the ignition system in PERFECT order when your carbs go on so that you don't install one "problem" on top of another.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
The diaphragm has to be able to hold vacuum in order for it to pull on / rotate the breaker plate the points are attached to. The best way to see if it works (once you've got a length of hose) is to remove the distributor cap, plug the hose on the the advancer diaphragm, and suck through the hose as you would a soda straw. If the advancer is good you should be be able to see the breaker plate in the distributor rotate slightly but noticably. If it doesn't move at all or there's no resistance to your sucking on the hose the advancer is no good. I'm honestly not sure if replacement diaphragms are available or not. They ARE servicable without replacing the whole distributor.
I wouldn't be sure that just the vac advance will kill you that badly-
after all, I never use mine on the track!
And at last look, SOME were available, but there are about 20
different kinds... ask Blunt.
The vacuum advance is effective in advancing the timing when the throttle is closed enough so that it is influenced by manifold vacuum. The dist runs only on mechanical advance on WOT. So it may be your initial advance that is off also.
