slow rev question
nbristow01
Ok, just a general 02 question..I am new to 02's. The one I have has 75k original miles. It sat for over 15 years never started. I was the first to start it..idles well, installed new points etc. Car revs slow...hard to rev it much past 4000. Drives fine but top spped is about 70mph. Are these cars really this slow or is this the result of a 32/36 that is just old and not doing well? i bet i am not putting out more than 70 hp it feels
i will be installing dual 40s this jan anyway but am just curious.
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
Sounds more like an ignition issue than a carburetion issue. The vacuum advancer maybe inoperative or the breaker plate stuck / gummed up in the distributor. How did the distributor look internally when you replaced the points? Did you remove the distributor or rotate it at all while servicing the points? Really sounds like retarded timing. A worn out M10 will still take an '02 way faster than you can legally drive.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
Maybe a retarded ignition or owner haha, i will check it out..I have a new MSD box coming as well as pertronix electronic ignition, red coil etc. Bet that may help wake her up
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
and your not opening the carb throttle FULL OPEN
when the gas pedal is held to the floor.
the carb throttle lever should tap against a stop
tab on the car - stand out side of the drivers door with
your right leg on the gas pedal, and you hanginf over
the open door looking at the back of the carb - listen
and watch the linkage tapping against the full open stop.
you'll figure it out from there
and sitting that long, the carb will need a minimum
of the top removed and the float bowel cleaned, accel
pump diaphram replaced, and all the passages blown clear
maybe the secondary circuit is plugged = your only getting indicated 70 mph out of it
theres a ton of other stuff to clean, adjust, replace with the motor before you try to go any faster anyway - for safetys sake
photos always hep us help you
Welcome To Your New Addiction
'64 R27 250cc #383851 18,000m
70 mph probably = no 36 barrel on the carb.
Could be stuck, could be throttle linkage's slipped, probably
not a problem with fuel flow (or you'd go unrunnably lean)
And maybe no power valve, either.
The kits for the 32/36 are pennies ($16 here in Seattle from Autosport)
and it's very good practice to get this one working right- all Webers
think alike, even if they work differently.
And it's worth real money here in good working order.
AND the Haynes manual that you WILL be getting covers both.
I'd fix it.
You should top out around 110 mph.
