Fuel Cat Enhancement Systm Leaded2unleaded ?????
Scott Sislane
What's the scoop on these things? I just ran across it on ebay.uk
Fuel Cat Enhancement System Leaded2unleaded
What is Fuel Cat?
FUEL CAT is a tin alloy catalyst that acts like a permanent octane booster, a combustion enhancer and combustion chamber carbon deposits cleaner. When the fuel flows through FUEL CAT fuel catalyst, a chemical reaction instantly takes place. The shape, temperature and speed of the burn are transformed, making combustion more complete and even, contributing to greater engine efficiency. FUEL CAT fuel catalyst aids the combustion process by ensuring that fuel is highly uniform, potent, consistent and stable. Just one FUEL CAT is all you need. It is effective for up to 400,000km.
FUEL CAT removes and further prevents the build up of carbons, gums and waxes. Internally, your engine will be far cleaner and more efficient. It is particularly effective for injector needles, nozzles, valves, piston rings and oil contamination. After the first 2,000km of using FUEL CAT, the oil in your engine can become particularly dirty as it removes carbon deposits from the engine. All you have to do is change the engine oil, and thereafter it should stay noticeably cleaner for a longer period. By keeping your engine clean, FUEL CAT optimizes compression and seals the combustion chambers from the crank case, preventing contamination of the engine oil.
How does FUEL CAT achieve Fuel economy?
The FUEL CAT fuel catalyst induces chemical reactions among fuel molecules at low temperatures (such as those our vehicles and fuel tanks experience) and it returns them to their original state at the conclusion of the reaction ready to initiate a new sequence.
Fuel molecules have a tendency to cluster together. At the point of combustion, the outer molecules protect the inner molecules from being covered with oxygen, resulting in some of the inner molecules going un-burned and blowing out from the exhaust as emissions.
When fuel is passed through the FUEL CAT fuel catalyst just prior to combustion, a reaction occurs which separates the clustered molecules so more of the fuel molecules surface area is exposed to oxygen at the time of combustion.
A comparison would be if you put a piece of charcoal in a furnace for 30 seconds. The result: the oxygen only surrounds the outside of the charcoal only allowing the outside of the charcoal to burn. The oxygen does not reach the core of the charcoal as it was protected by the outer layer. If you crushed the similar-sized charcoal into a powder, spread it out and place it into a furnace for 30 seconds, more of the surface of the charcoal would be exposed to the oxygen and a larger percentage of the charcoal would be burned.
This is what happens as the fuel passes through the FUEL CAT fuel catalyst. Clustered fuel molecules are separated so more oxygen can cover a larger surface area of the fuel molecules at the point of combustion.
The more fuel burned, the more energy created and less un-burned fuel will be emitted out from exhaust in turn reducing pollution.
A more efficient burn results in less fuel required to make horsepower. A cleaner burn means better oil chemistry and cleaner engine parts resulting in reduced maintenance.
How does Fuel Cat keep your engine cleaner?
Fuel Cat not only optimizes burning of fuel, but also keeps the engine clean by leaving no unburned fuel that can then turn into carbon monoxide, unburned hydrocarbon and free carbon (as soot) emerge from the combustion process. The unburned hydrocarbons and free carbon form gum or wax, and are loosely described as carbon deposits, which are baked hard, in the combustion chambers, onto piston crowns, valve heads (particularly the exhaust valve) spark plugs and interior surface of the combustion chambers. The piston ring can also be seriously affected and eventually become stuck in their grooves.
Fuel Cat regulates the speed and temperature of combustion which prevents micro welding between valve and valve seats; thus preventing valve seat recession.
Benefits of Fuel Cat Pre Combustion Fuel Catalyst
1) Better fuel economy. Saving between 8-16% on average
2) Low octane gasoline performs like premium.
3) Improve greater engine output (Torque & Horsepower).
4) Easier starts.
5) Remove and prevent carbon build up in the engine, due to its carbon cleaning properties.
6) Prolong engine life.
7) Reduced emissions of harmful gases.
8) Less engine and fuel system maintenance.
9) Increases the lifespan of your catalytic converter of your exhaust system.
10) Reduce pinging due to engine burning on lean mixture of fuel and air.
11) Suppresses bacterial growth in gasoline, thus fuel stays stable and fresh during storage.
12) Noticeably fewer flat spots when used with M/Cycles, Scooters.
13 Helps leaded fuel engines to run on unleaded, without timing adjustments.
THESE ARE OUR NEW IMPROVED MODELS
NOTICE THE DIFFERENCE OR FULL MONEY BACK GAURANTEE.
SEE OUR 100% FEEDBACK.
I never discount the possibility of new technology, but for you viewing pleasure some old products that didn't make the cut.
EPA's Evaluation of Fuel Economy/Efficiency Products
EPA tests fuel saving products to determine whether they significantly improve fuel economy as claimed in their ads. However it does not conduct any durability tests and therefore, is in no position to inform us what harm these products might bring to a car or its performance. It warms that on board diagonostic systems associated with modern vehicles' sophisticated and comple emission control systems might be adversely affected by retrofit of these products in alarming the driver to problems of emission control and fuel delivery.
These Auto 'Fuel Economy' Products Don't Work - EPA
EPA found the following products claiming in their ads to improve car fuel economy or efficiency didn't do so. As warned above, there are some potential harms possible.
Air Bleed Devices
These devices bleed air into the carburetor. They usually are installed in the Positive Crankcase Ventilation line or as a replacement for idle-mixture screws.
ADAKS Vacuum Breaker Air Bleed
Air-Jet Air Bleed
Aquablast Wyman Valve Air Bleed
Auto-Miser
Ball-Matic Air Bleed
Berg Air Bleed
Brisko PCV
Cyclone-Z
Econo Needle Air Bleed
Econo-Jet Air Bleed Idle Screws
Gas Saving Device
Grancor Air Computer
Hot Tip
Landrum Mini-Carb
Landrum Retrofit Air Bleed
Mini Turbocharger Air Bleed
Monocar HC Control Air Bleed
Peterman Air Bleed
Pollution Master Air Bleed
Ram-Jet
Turbo-Dyne G.R. Valve
Vapor Bleed Devices
These devices are similar to the air bleed devices, except that induced air is bubbled through a container of a water and anti-freeze mixture, usually located in the engine compartment.
Atomized Vapor Injector
Frantz Vapor Injection System
Hydro-Vac
POWERFUeL
Mark II Vapor Injection System
Platinum Gasaver
V-70 Vapor Injector
SCATPAC Vacuum Vapor Induction System
Econo-Mist Vacuum Vapor Injection System
Turbo Vapor Injection System
Liquid Injection
These products add liquid into the fuel/air intake system and not directly into the combustion chamber.
Goodman Engine System-Model 1800
Ignition Devices
These devices are attached to the ignition system or are used to replace original equipment or parts.
Autosaver
Baur Condenser
BIAP Electronic Ignition Unit
Fuel Economizer
Magna Flash Ignition Control System
Paser Magnum/Paser 500/Paser 500 HEI
Special Formula Ignition Advance Springs
Fuel Line Devices (heaters or coolers)
These devices heat the fuel before it enters the carburetor. Usually, the fuel is heated by the engine coolant or by the exhaust or electrical system.
FuelXpander
Gas Meiser I
Greer Fuel Preheater
Jacona Fuel System
Optimizer
Russell Fuelmiser
Fuel Line Devices (magnets)
These magnetic devices, clamped to the outside of the fuel line or installed in the fuel line, claim to change the molecular structure of gasoline.
PETRO-MIZER
POLARION-X
Super-Mag Fuel Extender
Wickliff Polarizer [fuel line magnet/intake air magnet]
Fuel Line Devices (metallic)
Typically, these devices contain several dissimilar metals that are installed in the fuel line, supposedly causing ionization of the fuel.
Malpassi Filter King [fuel pressure regulator]
Moleculetor
Mixture Enhancers (under the carburetor)
These devices are mounted between the carburetor and intake manifold and supposedly enhance the mixing or vaporization of the air/fuel mixture.
Energy Gas Saver
Environmental Fuel Saver
Gas Saving and Emission Control Improvement Device
Glynn-50
Hydro-Catalyst Pre-Combustion Catalyst System
PETROMIZER SYSTEM
Sav-A-Mile
Spritzer
Turbo-Carb
Turbocarb
Mixture Enhancers (others)
These devices make some general modifications to the vehicle intake system.
Basko Enginecoat
Dresser Economizer
Electro-Dyne Superchoke
Filtron Urethane Foam Filter
Lamkin Fuel Metering Device
Smith Power and Deceleration Governor
Internal Engine Modifications
These devices make physical or mechanical function changes to the engine.
Dresser Economizer
Fuels and Fuel Additives
These materials are added to the gas tank.
Bycosin
EI-5 Fuel Additive
Fuelon Power
Johnson Fuel Additive
NRG #1 Fuel Additive
QEI 400 Fuel Additive
Rolfite Upgrade Fuel Additive
Sta-Power Fuel Additive
Stargas Fuel Additive
SYNeRGy-1
Technol G Fuel Additive
ULX-15/ULX-15D
Vareb 10 Fuel Additive
XRG #1 Fuel Additive
Oils and Oil Additives
Usually these materials are poured into the crankcase.
Analube Synthetic Lubricant
Tephguard
Driving Habit Modifiers
These are lights or sound devices to tell the driver to reduce acceleration or to shift gears.
Fuel Conservation Device
Gastell
Miscellaneous
BRAKE-EZ
Dynamix
Fuel Maximiser
Gyroscopic Wheel Cover
Kat's Engine Heater
Lee Exhaust and Fuel Gasification EGR
Mesco Moisture Extraction System
P.S.C.U. 01 Device
Treis Emulsifier
For original source please visit FTC's Facts for Consumers: "Gas-Saving" Products: Fact or Fuelishness?, based on EPA and www.fueleconomy.gov
Last Update: April 25, 2004.
