Water leak??
kenkoy214
Hi guys. I am getting leak by the front of the motor by the outlet of the water pump. Is this possible of water pump failure? I just installed the cyl head from a valve job also replaced the thermostat. I started the car and run a few blocks then noticed water leaking. Do I just replaced the water pump or try bleeding the coolant? How do you guys bleed it? You think I might have gotten a bad thermostat? please advice me. Thank you
If you peer down at the water pump from above, you can see a 2mm hole in the water pump case. This is a weep hole. If the water pump is shot, water will run out of this hole once the engine gets hot. If not, maybe you lucked out and have a loose hose connection somewhere.
67 Caribe 1600
76 Ceylon 2002
