removing engine via dropping subframe
repoman
Just curious....
If I drop the engine by unbolting the struts and subframe, leaving the tranny in place, will the engine balance on the subframe (with the wheels still on) and rest against the end of the tranny or will it take a nose dive and hit the fan?
1974 2002 Verona & 1973 2002 Riviera
1982 320iA & 1983 320iS
2002 Ford Excursion Limited 4x4 7.3L PSD Wife's
The short answer is yes, but if you drop it too much you will snap your rubber transmission mount. I would suggest dropping it a little at a time and alternate between the subframe and the tranny mount (remove the bracket). Also the balance point form right to left is fairly small, so use ample blocking under your jack to stabilize any movement and prevent the motor from tipping into the right chasis rail or fender well.--Jim
Good to know...thanks!
I'm not too worried about the body as I may just cut the nose off and pull it out the front. The body is rusted and I will be hauling the carcuss off for scrap.
I was hoping to use the subframe/wheels for an engine dolly to move it around. I do have a engine hoist and stand, but time is of the essence.....
Just looking at how BMW MT installed the complete assembly in the Inka tii is a little scary. The jack would have to be positioned carefully.
Maybe you could somehow jack up the transmission to keep the rear mount from separating. Then again, why not just pull everything at the same time?
I used this method on my 73, and will probably do it on the 76.
First I removed the drive shaft.
Then got the traney loose, don't forget the reverst light switch wires and spedo cable.
Get all wires, hoses and linkage disconnected from engine.
Remove nose or get a 3 foot chain.
Attach engine crane to motor.
Raise body.
Remove subframe bolts.
Lower motor and remove.
Good luck
Arden
http://ardens-2002tii.blogspot.com/
71 2002, tii, Schwarz
72 2002 tii, Polaris
76 Trans Am, Sterling Silver
96 Volvo 850, Daily Beater
Parts Cars: 73 2002 Malaga, 74 2002 tii Granatrot & 76 2002 Verona
DO NOT FORGET THE SEERING ROD.
You must disconnect the steering rod from the steering box. There is a pinch bolt for that purpose. The steering box drops with the subframe, complete struts and suspension.
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
