#73's Part List {Holiday} Stock Stuff and Stocking Stuffers
#73
All questions answered, all offers considered. List Updated 12/18
Email best/quickest: thedigitalplan@optonline.net
Prices listed = 'local' meet-up, carefully packed shipping possible for +.
Note A - For very heavy parts (like drums) shipping is a bit up there - best quick delivery rate seems USPS 'flat rate' box @ 13.95!
Local meet up is most cost effective for bigger/long items.
Note B - 'Dibs': I always stick with an 'in order received' for all requests....
However, to be fair to everyone - including my landlord (!), I can only 'courtesy hold' a part for a couple of days without payment or reply... Thx.
FS or Trade*:
Valvoline Oil Filter L183/PH-2816 (New Never used Scuffs on dome, box worn) $2
Heater/Fan Plate (New - minor shelf storage microscuffs) $3
Package of Chrome Valve stem covers/sleeves and caps (New//Never Used) $3
Center Pad from late 400mm Steering Wheel? (Used, Fair, two 2mm dings on lower front lip , logo has some clear cracks inside -see pics-) $6
1 Behr Thermostat, 1 Wahler (Used no cracks, just need clean up - I believe both are 75 degree) $6 each
1 Clutch/Brake Pedal Pad (New;Mint in package) $7 ~SOLD~
Emergency/Rounded Lug Nut Remover (Used once) $7
Early; Raised Rear Roundel $11 ~SOLD~
Early-Early/1600 6 Fuse Fusebox Cover (New/Never Used, No discoloration, no cracks, some shelf microscuffs, 1 hard to see/photograph very slight scrape/line ... see pic 2) $12 ~SOLD~
Early Locking Gas Cap (Used condition, no key, no dents = camera reflection) $13 ~SOLD~
Late Front License Bracket (New - light scuffing from storage) $14
Shifter Surround & Boot (Used - Some nicks on base, small rips on vinyl boot - see pics) $15 ~SOLD~
2 Sets Prothane Poly Bushings (New /Never Used - 2 for Differential Carrier) $22 Both sets ~SOLD~,
2 Waterpumps (New, In Boxes) $22 each Left Pic ~SOLD~, Right ~SOLD~
Guibo/FlexDisc (New/Never Used with compression band ~but some surface oxidation~ on bolt tunnels and on compression band (band is removed after install) $21
Passenger Side/'Right Side' Motor Mount (New/Never Installed) $24
PBR/Axxis/Metal Master Metallic Brake Pads (New - still wrapped, Asbestos Free 76.5mm for base 02) $24 ~SOLD~
Locking Chrome Gas Cap (New, 7.5 to 8 out of 10 condition = some micro scuffs/nicks - retail shipped dusty & with key resting against {!?!}) $25 ~SOLD~
Tanner Panel Ignition, Start, Accessory Switch mounted on aluminum box & wired/fused (Some Scuffs, Scrapes) $25 ~SOLD~
2 Passenger Side Late Plastic Grilles (Used, nice, clean... one complete, one is missing the small plastic post by bucket) complete grille $28, grille w/o small plastic post/stem $21
Late Wood-Style Guage Cluster w/ Clock, Reads 66553 miles. (Fair+ Condition... one nick to bulb wire, clock lens has some microscratching, can polish out, black plastic on housing has some lighter areas, scuffs, not tested) $28 ~SOLD~
?!? (New old stock... Mint w/ small amount sticker or production smears on part of back - would polish out w/ Blue magic/mother's etc.) $29 ~SOLD~
Locking Chrome Gas Cap (New, Mint... some polishable microcratches from shipping/storage) $30 ~SOLD~
2 ATE Drums (New - Unused, Rust Marks on some of outter {non-contact} edges from storage... see pic) $34 ~SOLD~
ATE Slave Cylinder (New - Very Slight Surface Oxidation Specs by Part#... see 2nd pic below) $36 ~SOLD~
Distributor from 320is (Used - Good, 97K miles) $36
Prothane Polyurethane Bushing Kit #3-201 (New/Never Used - for both Front Control Arms and both Under Tow /Tension Rod/Front Support) $43 ~SOLD
Prothane Poly Bushing Kit #3-202 (New/Never Used - 4 piece Rear Arms) $43
Rear Wheel Arch Repair Panel Belgium Made by Van Wetzel International (New - a few tiny oxidation specs... 'biggest' in 3rd pic below) $46 ~SOLD~
Tii Downpipe (Used - Good, Solid Cond. Refurbished... Wire brush: rotary coarse, medium then by hand w/ fine brass, finally double coated w/ POR20 {the 1400 degree version of POR15}) $50 ~SOLD~
Luisi Leather Steering Wheel (Leather is nice but a bit light throughout - could use recolor/dye - or as is in daily... works w/ Nardi/Personal hub & horn button- not included, ~350mm/just about 13.75 inches) $77 ~SOLD~
Tii Clock w/ the "BMW MotoMeter" face, collar, wires, bulb (Used - Fair+ Condition, lens some microscratches & spots, worked {time and light} when removed, mount posts taken off?! by previous owner of tii... was in dash: wired but unsecured, collar has a crack & glue residue inside... left inner screw near '9' has nick... see pics) $85
Clean Pair of Weber 40DCOEs with 2 Piece Chrome(d) Intake Manifold, and 2 K&N Chrome Oval Filter Assemblies w/ filters, car to mani soft plastic gaskets, and all mounting hardware (More Detailed Pics & History: http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,332821/
[strikethrough]As a set: $515 local. Carefully Packed Shipping Possible.[/strikethrough]
Note: After 2 weeks on FAQ = alot of interest but no-goes, MIA/disappearing guys... they're now up on ebay:
Item #160387904739, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160387904739&viewitem=&sspagename=STRK%3AMESELX%3AIT
Best Luck... Hoping they stay on a 2002.
OTHER:
Bosal Chrome Exhaust tip for 525i? May fit other? (Some shelf/package scuffs) $8
1987 BMW 325 es Running Parts Car $345
More Info/Pics:http://newyork.craigslist.org/lgi/cto/1499066914.html
*WANTED/can Trade above stuff for:
1. Front DS Firewall plastic 'Shroud' (in better shape than in pic/my current)
2. A Battered/Unloved/Damaged Front Airdam
3. The Roundel Issue where Jenny Morgan calls the 2002 some less than choice adjectives in her column...
4. Plastic door latch/catch end covers.
Thx,
__/ 0| \ _
'-O----O--' #73 (I'm looking for a couple of parts *here* / 4 Sale parts *here*).
I would like
1)Set Prothane Poly Bushings (New /Never Used - 2 for Differential Carrier$22,
Early rear raised letter emblem $11.00
Rear Wheel Arch Repair Panel Belgium Made by Van Wetzel International (New - a few tiny oxidation specs. $46
thanks,
Julio
'69 2002 (M2 for 2012) daily driver
'71 911 T (2.4s) powered Weekend joyride
'67 VW Crew Cab Turbo truck parts hauler
www.eurovintageparts.com
Thx guys - all replied via email. List updated above...
Hmmm...I did not see an email response as yet. I see the gas cap is now sold....how about the Inst cluster?
Shipping to zip 92821 via parcel post?
Thanks
1974 2002 Verona & 1973 2002 Riviera
1982 320iA & 1983 320iS
2002 Ford Excursion Limited 4x4 7.3L PSD Wife's
