san fran c.l. tii
tyjoja
If that's the one, here is a summary of the emails I received from the seller over a month ago. I do have some pictures, but I am too stupid to attach them. I never looked at it in person:
I bought this car back in 1998, I drove it for a couple of years before passing it along to somebody in 2000/2001. As chance would have it, I bought it back from him back this past May. That person didn't really keep up the maintenance like he should have unfortunately. As a matter of fact, the engine was running really poorly to the point that it was almost un-driveable.
I have it to a point now where the engine is running as stronly as it ever was, and is reliable as well.
This is not a stock car, so if that's what your looking for, read no further. The car looks pretty good from 15 to 20 feet away during the day. It does have some rust in a couple of spots, but it runs and drives well, but could use new idler arm bushings.
Pics are in a winzip file, just unzip to have a peek. car is located in Pacifica, CA
As far as it being a good daily driver and being reliable, I'd say yes as I have driven it to Fairfield, Santa Cruz, and Antioch quite a few times since getting it back on the road with no problems. I would highly recommend changing the idler arm bushings (I had a pair, went to put them on one day and couldn't find them!)..
Rust - well almost all these cars have rust someplace:
no rust around any of the shock towers, a tiny tiny bit of surface rust along the trim under the back quarter windows, also a little on the doglegs of the fenders, a couple of small spots about dime sized on the passenger side floor pan.
List of engine enhancements
Dr. Schrick 292 degree cam
Rennsport exhaust headers
pertronix 009 type electronic ignition
MSD 6A
Top End Performance K&N intake
Behr 320i radiator
320i 5 speed gearbox
has a strut brace installed (not sure about the origin/make of it)
thicker than stock sway bars front and rear
320i front vented disc & 320i rear drums
stainless steel brake lines
battery has been relocated to trunk
Hella H4 Headlights
E30 Sport wheels
I belive that the front clip was replaced, from the radiator bulkhead forward. There is no rust in the trunk, shock/strut towers, rockers, or at the bottom of the windows. The rear panel was dented in, but pulled back out and repaired. I found the idler arm bushings the other day, I'm debating on wether or not to install them :)
I will be around town during the thanksgiving holiday if you still want to check it out.
[/img]
Current:
- 1970 Colorado 2002, 1982 323i, 1972 Porsche 914, 1956 Porsche 356A Coupe replica, 2003 Mini Cooper S
Past:
- 1980 320is Turbo, 1972 Malaga 2002tii, 1973 Polaris 2002tii, 1973 Sahara 2002, 1981 Alpina C1 2.3, 1989 M3, 1984 Hardy & Beck 327S
