Pic Request....Lowered 02's with 15" rims
jrhone
Now for the magical question....
WHO RUBS ??? (hitting bumps, potholes and hard cornering, etc...)
i do if i enter a driveway at a 45 degree angle too quickly. as long as i go in slow im fine. otherwise no rub out back or lock to lock. im pretty low though
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Based on personal experience running 15" rims, I'd strongly suggest you look at 195/50's, not 55's. You and I both have cars which have been significantly lowered, and the 55's will rub that much more in the inner fender wells during heavy cornering. I switched to 50's and haven't looked back, and I really didn't find a noticeable difference in ride quality.
What did you have before sports ???
I plan on running momo star 15 x 7 et 25, on Bilstein hds, w/suspension technique springs. I am looking for someone with this set up so I can know if I will be cutting, rolling, or" turboing" the wheel wells...
and Thank you for your response...
I rubbed on the fronts on hard dips until I installed the sports. This is also with 0 degrees O' camber in the front. Once that changes, there will be very little risk of rubbing for me.
Time is the ruler of all...
