1.8l what to do with it?
biker50610
i have a running motor out of a 83 320i sitting here at the house. what to do with it? its not like there is a big market for them. so should i strip it and see what i can make out of it with little to no cash or what? if i where to just dump it into my 02 i have the full k jet with it or just swap over to weber 40's? or just use it as a paper weight?
I'm with Harv...the engine is very smooth, has a shorter stroke than the 2.0 so it revs well, has 9.3:1 compression stock, and uses a significantly lighter version of the 215mm flywheel (if you've got it). I've got one in my green car and I have no complaints.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
