IE exhaust clamps
mkanow
I was wondering if any of you IE exhaust owners are having the same problems I am. I love the system, the build quality and sound is awesome, except I am having trouble with the clamps, especially, the clamp connecting the resonator to the pipe going over the rear subframe, and the clamp holding up the tailpipe (side exit). My tailpipe keeps sagging, and the center section keeps coming loose. Are there any other clamps that I can use? Loctite?
TIA,
Mark
'72 Riviera Blue: Family Owned, 60K Original Miles
Mods: 5 speed, 3.91 LSD, 15" BBS RA, Weber 38/38, Recurved Mech Dizzy, Pertronix, Eibach springs, Billy HD rears, GR2 struts, IE Urethane Bushings, E21 Recaros, IE exhaust
Mine was doing the same thing. Actually my center-res section eventually broke apart. (so get things tightened up and supported)
After having the center section replaced with a long-narrow one, I had all of the connections spot welded to keep them from turning or coming loose again.
Jack be nimble - Jack be quick
If Jack isn't, he's gonna get his ass burned!
TIA,
Mark
I threw the IE clamps away and got proper 2 piece exhaust clamps...the same style as the OE BMW clamps and all my issues were solved. Or tack weld it as mentioned above
70 M2 2.5L
