You blockhead...
TobyB
Well, a friend gave me a well- used E30 1.8 engine,
so I took it apart and weighed it.
Block- 80 lbs.
Crank- 30 lbs.
E21 block (x2) 90 lbs.
Late 2002 block 100 lbs.
All 2L cranks- 40 lbs.
So, I wonder if the 'E30 block is 30 lbs lighter' myth really refers to
the block and crank, or if the early 2002 blocks weigh 110?
I feel like a Moe-Ron for not weighing the block for the last race motor...
Actually, the crank difference is 4 counterweights! The 1.8 crank
is not fully counterweighted and the 2.0 is.
There are racers who lighten them, and at least one who took them
all off! (Yes, Jeff, that's you)
And, as I've never heard of anyone having trouble with a BMW block,
I'd go for the lightest one I could... getting weight out of the engine
is a huge bonus, as it's so far forward. But it's noticable on the E30 block
how the casting has less material in the bores...
I'll weigh all the parts next time I'm down there.... I don't have a really good
grasp on the overall weight, and there are a lot of numbers floating around.
The 215 clutch and flywheel (lightened a bit) weighs #30, though...
I am using an e30 block for my latest race build, the weight delta is totally noticable with 2 bare blocks and I was having an 02 block machined for a friend even the machinist commented on it.
Kind of a cool want to drop 10 or 15 lbs easy off the front subframe.
I have heard that the E30 block has extra ribbing. If that's true, that must be how they get away with less iron elsewhere? I wonder if the E30 block can still be bored to 92mm safely.
Too many cars.
