M20 Tstat housing question, are New OEM & factory same ?
DanOKC
This is on a 83 528e, the original housing was one complete cast piece, the
replacement I got from autohauz AZ, is all cast, except for the small hose outlet on the bottom, is now a press fit aluminum pipe, which came loose after first 30 minutes of operation. I'm either gonna try to tap the housing & put in a threaded brass plumbing fitting, or try to find a good used one if all new ones are made this way. The old one's surface is slightly warped and/or corroded, so even with a new cap, and seal, it tends to seep a little. Here is a link to picture of exact same one I got, says " RONAK" on it. The press fit pipe is the one poking out at the lower left.
http://www.rmeuropean.com/Part-Number/Thermostat-Housing-NOTE--Also-use--%282%29-07-11-9-919-228-plug-%282%29-07-11-9-963-200-seal-__11531730470_MTC_CB4144DE.aspx
I'd order one from maximillon if I knew it was all one cast piece
2002 owner since 1980
The Ronak one is a POS. I tried one when they came out and when I tightened a sensor the thing cracked on me. This was of course the sensor you must do last as the fuel rail is in the way.
I used OE before and will continue to do so. I've never had a problem with the OE BMW ones.
HTH
Tom Jones
The small hose fitting on the OE ones is pressed in but I have not ever had a problem with them in use of what must be over a hundred by now :)
Tom Jones
