AHHH!! Dont turn on you freakin oil pressure light! HELP!
Meintii
Ive noticed that the past two days ive driven my car that the Yellow light above the turn signal, the oil pressure light, has started to come on when I slow down from speeds above 45.
I push the clutch in to stop a stop light or stop sign, the and the yellow light comes on, and then goes out once i start moving again. It still seems to run/idol fine.
Also, it has been running REALLY rough in the mornings when I first start it up, but when i push the gas a little after about 45secs of running it will go back to normal running. I i do not push the gas, it will cut out and make a bunch of ruckus.
I recently replaced the oil sending unit... What should I check to fix this?
BTW this is a 72 tii.
THANKS FOR THE HELP!
-Zac
Zac Cardinal
1972 2002tii's Blog
1976 2002 "Margie"s blog
You should check the oil pressure.
Low oil pressure at idle can point to excessive wear and loose tolerances. Meaning, it may be time for a new bottom end. Especially if you changed out that sender due to the light flickering.. Get an oil pressure gauge on it asap and see where its at.
(O=o00o=O)
Will do. I didn't change the sensor to stop the light from blinking.. It was leaking oil so I changed it... So how exactly do you check the oil pressure with a gauge? Ie: where do you put it?
did you replace the oil pressure sender with a stock unit? just a thought... i have a sensor in my s14 set to trigger my oil light if it drops below 18PSI.
i bought this sender specifically to do this. a stock sender typically triggers at 7PSI i believe. did this just start after changing the sender?
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
