Steering Play
tgallie
Is the steering wheel tight on the steering shaft? Pull the horn button and look inside there.
Maybe the bolts holding your steering column have loosened a bit. Crawl under the dash and wiggle the steering and see if something's come loose. The PO of my car must have decided to reduce weight and left a couple of the bolts out. I'd rather have them all in there, myself.
A serious surprise may be in your future if there are loose parts in the steering column. I'd get to the bottom of it soon.
Jerry
no bimmer, for now
Does not sound like a steering box adjustment issue.
The steering column is supposed to be preloaded on install. You'll need a helper to push down hard on the steering wheel while you tighten the bolts at the flex disc under the hood. At least I think that's how it's done. Check your Haynes - I beleive it's described there.
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
