'84 318i - Euro Conversion
I'm not sure if you guys are welcome to e30's, but i'll give it a go anyways, I do share the same engine as most of you guys.
I've been lurking on this forum for a while, mostly learning what the M10 is capable of. I've never really introduced myself or my car so here it is. It's my first car, a 1984 318i (e30). It's a San Francisco born car, I'm the 3rd owner (should be the 2nd, a Mexi dealer in Chula Vista owned it for a month and then sold it to me). Original Paint too.
I've done a lot to it, but nothing really mechanically. I have a wimpy M10 currently, but I figure, why shove money towards performance, and have a car that looks like crap? If I wanted to do that I would have become a ricer. So I'm directing most of my funds towards appearance and finding and installing coveted OEM options. I'll let the pictures say the rest.
Here is a picture of it at it's first clean car contest (BMWCCA San Diego Clean Car Contest '09). Not a very flattering pic, but you will be seeing it more and more at BMW events in SoCal.
pic of the toolkit as of 2 days ago, finally got my second red screwdriver. I took the blue cloth out for this pic. the rest of the tools are coming in the mail within the next few days
This is how it originally looked so I think it's coming along nicely.
Yes, my headlight cleaning system is fully functional as well as the intensive wash.
I document everything I do to my car in this thread:
http://www.e30tech.com/forum/showthread.php?t=70925
My plans for it, are full OEM m-tech 1 kit, s14 swap, slight suspension drop (emphasis on slight), and lots of OEM options.
VERY VERY clean E30! Well done on picking up such a untouched beauty. The future plans sound very good also. I look forward to seeing results!
holy negative camber batman!!!
02 Golf Yellow cruising the border of NSW/VIC!
tii pistons, 293, double valve springs, 40mm DCOE's, sump baffle, sway bars, lowered, 5spd, big brakes, 3pc wheels, bucket seats. Approx 150+hp
  • 3 weeks later...
  • 1 year later...
Audemars Piguet watches are wound automatically with the motion of the wearer's wrist. Once the Piaget replica winder null, the replica ebel will stop at last. If you don't wear your automatic Hublot for sale every day, a Rolex watches winder is a very good investment as replica Franck Muller winders are available to store automatic Longines watches and keep them wound. It's great for A.Lange & Sohne watches collectors who don't want to reset the time and calendar of an idle Concord watches regularly. There are many factors that you will need to take into account when it comes to selecting a winder, such as its battery or electrical power source, noise level of the motor and check whether its directional timer needs to be set or is automatic or not. Instructions If you own one automatic replica Glashutte and wear it daily, a Panerai for sale winder is superfluous. Collectors with several automatics that get only occasional use should consider a winder to keep their Breguet replica wound and lubricated. If you own two automatics, choosing a Blancpain replica winder to accommodate a single replica Ferrari is adequate. If you expect to collect automatics, find a multiple A.Lange & Sohne replica winder. Avoid inexpensive winders that only rotate replica omega in a specific motion. Automatics are designed to be wound with varying twists and turns of the wrist. Choose a DeWitt replica winder that mimics wrist movement. Choose a replica Maurice Lacroix winder that's right for your Christian Dior replica. Audemars Piguet for sale are smaller than modern timepieces with a dial diameter under 36 mm. Modern Jaquet droz replica have dial diameters up to 45 mm and larger. Some replica Hublot may be too big for the winder and strike each other in the box. Consider an enclosed Panerai replica winder that will protect the oris replica from dust. A velvet-lined winder will cushion the Cartier replica. Tips & Warnings ?Choose a beautiful winder that complements your furniture perfectly. Wood grain or piano black-lacquered boxes on a desk, table top or high shelf, and you'll be surprise with the results. ?Do not let a winder rotates a Concord replica in a single motion, or it may cause uneven wear of the movement. A replica Bell & Ross winder is a motor device with build in electronic programming. Using an electric Concord for sale winder to wind your favorite croum for sale on a regular basic can ensure your wrist or pocket Glashutte for sale continue to work at its best. Fortunately, using and maintaining a ebel replica winder is earlier than you think. Battery InformationMany makes and models of electric Longines replica winders can be powered with D batteries or with the included AC adapter. If you are using D batteries to power your replica U-boat winder, manufacturers recommend using alkaline batteries, rather than rechargeable, for best results. The D batteries can be installed in the device by lifting the battery cover. Winding InstructionsElectric Tag Heuer replica winders are powered on and off using an "On/Off" switch located on the back of the device. Users are encouraged to choose a winding program for their Patek Philippe replica before putting the Graham watches on the winder. Most models of Rado for sale can be wound both clockwise or counterclockwise. Once the program has been chosen, you can flip the replica Jaquet droz winder switch to "On." The winder will stop automatically when the program has been completed. Care and MaintenanceProper care and maintenance will keep your Baume & Mercier for sale winder functioning at its best. This includes keeping your Ferrari for sale winder clean, out of extreme temperatures and away from excess moisture. Should your chopard watches winder need to be cleaned, you can wipe it with a soft cloth that has been dampened in a solution of mild soap and water. If you will not be using your Tag Heuer for sale winder for four weeks or more, remove the batteries to prevent corrosion ,which could damage your Baume & Mercier replica winder. Trouble-solving If your ebel for sale winder is winding mucb slower rate than usual, there maybe something wrong with the batteries. Make sure the battery is connected with the correct polarity. If the batteries have been inserted with the correct polarity and the device is still not working well, remove the old battery and replace the new one. Finally, if all else fails, the AC adapter may help you solve the problem.
