Odometer Repair
Thanks to the FAQ thread, I was able to get my odometer repaired last night, as it stopped turning like they all must eventually do.
I thought these pics would make it more helpful, if you have to do yours.
Of course, the pictures loaded in rev order. (!)
Scott
post note: As mentioned below, make sure the temporary pin (nail) is long enough to protrude out the opposite side so it holds the number wheels in place properly. I use a 2" finishing nail, absolutely perfect length.
Edited by sislane
and how do you know if there's more than 99,999 miles?
the #'s stay in place, you do not turn the #'s, so you start where it left off.
there's no "reset", just analog wheels w/ printed #'s.
no way of knowing if they have been turned back or fwd...
Scott
Scott
what does that mean? would it read 99,999 forever, (this would be the 'numbers staying in place', or does it 'start where you left off', i.e. the next mile would read 0, and then 1 etc... ?
and what does 'you do not turn the numbers' mean? I'm sorry, I just have no idea how those statements mesh...
1984 Pininfarina Spider Azzura (Fiat 124): sold
1992 300ZX Twin Turbo: sunny days
2001 Toyota 4runner: sold
1974 BMW 2002 automatic: daily
1991 BMW 325iC: sold
1986 BMW 528e: daily
  • 1 month later...
  • 2 years later...
old post, i know but just wanted to let other FAQ'ers know that this works. I had to use a punch to get the geared pin out and tapped all around with a hammer and chisel, but it worked like a charm. two thumbs up, thanks gents.
I just did it last night myself, works great! I do have a word of advice though. I chose a nail size as a temp replacement that was just a "tad" longer than the span it needed to pass thought. I dulled the end of the nail, but when I did I made it a "tad" shorter than the span I needed. As a result the nail didn't quite make it to the other side. It was well within the last number wheel, though. Because it didn't go through all the way any motion laterally disengages the positioning gears (the grey ones you see in the pictures above) from the number gears and the numbers can shift a bit resulting in them being off center on display when you replace the original shaft. Be careful if you do this to make sure the temporary shaft passes all the way through, this will maintain the original position of the numbers. I was able to coax them back into place, but I spent 2 hours correcting this simple mistake to get it to read correctly. Learn from my mistake if you are going to do this very effective and otherwise easy repair. Also, you really do't need to make much of a punch in the shaft. I was surprised at how sensitive it is to these divots and had to sand them down a bit. But hey, now I'm rolling with the odometer working, awesome!
1972 Bavaria (sold)
1985 535i (sold)
1986 535i (sold)
1996 328is daily driver
1973 2002
1968 Porsche 912
1973 Triumph TR6
2 - 2012 Hotwheels BMW 2002s (Inka and Chamonix) 0 miles! (both are #21 of 247!!)
  • 2 years later...
I
I just did this today as well. though unlike you guys I just ended up taking the whole thing apart until I realized the problem was that lead gear.  :unsure:
I find that slightly clamping the shiny part of the shaft with a vice works better then punching it.
  • 1 year later...
Great tip thank you !!!
73 inka 2002 w/ fuel injection & 5 speed, LSD
