Sign in to follow this
2002guy
rear brakes
7 posts / 1300 viewsLast Reply
hey all, i got myself a 320i parts car to do the big front break conversion, i will be taking the rear brake setup to put the drums on.. i was just wondering if there is much more to convert the rears to disc or is it just oem parts..
thanks in advance
Ricky
there is a whole write up in the FAQ section. Should answer all of your questions.
i checked the faq section and there is a right up for the 320 drum conversion but no rear disc brake conversion
search for rear disc brake conversion-
there are several kits that use VW calipers.
After that, it gets harder.
Did Lee do something with rears?
ya he has massive rear brakes... i know theres a set up that uses corvette calipers and rabbit rotors.... but from what i understand i need to modify the hubs i just really wanna make sure before i start
Roughfly!
You need the front rotors from VW Mk1-2
I dont remember if they were vented or not.
The rear calipers from Golf, Passat, Jetta with emergency brake built-in.
More or less the hand cable
Brake line and fitting.
AND a custom bracket to center the caliper ( Advark or Ireland )
You also need to downsize the 2002 rear hub to fit the VW rotors.
All the details were in the archives.
Roughfly!
