pwagon717
15x8 et 12
6 posts / 1900 viewsLast Reply
What is needed to fit these at the rear of 2002, is anyone running this setup with the low et? Pictures or anything wouls be a great help
15x8 et0 with turbo flares. with the 12 you will still need to run turbo style flares. But might want to check on the inner clearance.
Draco, are you running 15x8 w/ 0 offset with only turbo flares? I was wondering if this would work.
What kind of suspension do you have?
I have sport billys and H&Rs
Sean,
Curtis in Florida has this setup with 225/50 in the rear amd 205-50 up front. I am going to run the same set-up. Getting custom barrels made for my epsilons. I am going to try 8.5 with et6 if they can make it for me for the rears.
Le
I'm hoping to run 15x8.5 or 15x9 (et1 on the 9, et~8 if 8.5) with 225-45-15's with turbo flares. Le, would you mind fitting one of your rear wheels on the front and taking a picture? Do you have bent struts? camber plates?
..check my FS ad for kosei's..
I run 15 /8 on rear w/ t bo flares and 225/50s..... and a spacer.....
