1.8i head for Megasquirt?
Also, the benefit of having the injector ports in the head is that I wouldn't need a new throttle body, I'd just use my DCOE carb body (on the Lynx manifold, my current settup) as the throttle body, as opposed to getting a TWM throttle body for it and trying to run with just 2 injectors.
Well, heck, there's your reason! Use it!
The cis injectors pushed in with a stiff rubber bushing.
You will have to open the holes in the head up a bit and make a rail.
The 318 rail fits the 318 manifold... although the spacing will be
about the same- might be worth getting one and trying.
If you use flattop pistons, now you need a turbo! The 8.very little
compression ratio would be great for a bar or so.
If you want more compression, talk to Jeff Ireland-
they have a few solutions to get some dome in there.
It's a good head design.
Wait, are you sure that the injector ports need to be 'opened?' I thought I would just need to install new bungs for the EFI injectors, such as these:
http://www.bitzracing.com/products/injector_bungs/injectorbungsdetails.html
It looks to me as if the CIS bungs have already been removed from this head, and that I would simply have to press these EFI bungs into the ports and be good to go; does anyone agree/disagree with this? Thanks!
-Carl
Hard to tell. The Porsche CIS rubber injector plugs don't really look like the BMW ones-
there's a relief machined into the port in the BMW head to retain the plugs,
and the Porsche ones look straight. But it's hard to tell from the pix.
However, I played around with some parts before I left this afternoon,
and the holes in the head are just about the right size for the
318 injectors. In fact, if that relief wasn't there, they'd be a good fit.
As it sits, you might be able to get some larger injector seals (they look like
chubby o- rings) and get them to sit nicely in the relief.
And you heard right- the 318 rail spacing and angle are good.
There's interferece with the regulator mount, but that's no big deal.
Hey, those are some great pics, thanks for checking that for me! I still think the Porsche bungs have a good chance of fitting correctly, but it looks like either way it could be made to work. I'm just glad the spacing/angles for the fuel rail work! One other question now though. It was mentioned that the 1.8i head has a bit lower compression than the other combustion chamber geometries, so would it be possible to just have the head shaved a little bit to get back to the ~8.5 'stock' compression? Or would so much have to be removed that valve/piston and/or cam chain length issues would come up? Thanks again for all of the great help guys, the 2002 forums are the best!
-Carl
