"The Butterstick" build (Turbo MS EDIS Stroker)
PabloM
JE pistons and a s14 crank , sounds good to me . how much bhp and lb ft are you after
My turbo and injectors will max out at just around 250 hp so I want to get somewhere close to that. When I get bored of that I'll try to find a gt28rs turbo and some serious injectors and see what's what, but that's a ways down the road.
i dont think this will be hard to do , i take it you have a 2.3 crank ?
I'm 95% sure it's the 2.3 crank. Is there any way to tell? Anyway here are some pictures
valve train
pistons
crank
The brown spots on the cylinder walls are just oil and rub off easily
block
head
head
Rebuilt starter motor in the background. Stock camshaft.
cam
It's all about momentum
  • 2 months later...
Update time:
Been a while since I update and I've collected a few more parts.
First off, the megasquirt stuff. It's Megasquirt I v2.2. Came with a relay board and all the sensors as well as the main harness and the cable to connect to the computer. Hopefully everything was soldered correctly...
MS box
MS kit
Second, I got some 37 lb/hr injectors for $55 thanks to Andrew(2590402) and they came with a free Innovative LC-1 wideband o2 kit!!
Injectors
Wideband o2
S-14 rods also came sporting ARP bolts and the new bearings for those should be here next week as well.
Rods
ARP bolts
Also bought most of the gaskets minus head gasket. Now all that's left is some main bearings to assemble the bottom end and then I still need an e12 head as the one I got is cracked.
  • 1 month later...
  • 1 year later...
  • 4 years later...
