Sign in to follow this
Transmission Identification Help required
2 posts in this topic Last Reply
I have a transmission out of a 1502 and is marked inside the bellhousing with 3 sets of numbers. They are 232017001, 225, & 33.Can anyone help me id this box and supply info on what the ratios are
None of those numbers you quoted match any part numbers either for the complete 4 or 5 speeds used on '02s or for the aluminum housings themselves. Suspect they're casting numbers. Don't have the info in front of me, but both the 1502 and the 1600 use a 4.11 final drive, and I suspect they use the same gearbox. If your gearbox doesn't have the extra 80mm section between the main casting and the tail piece, it's a four speed. If it is a five speed, perhaps it's from a 320 (don't have a 320 parts book to check)
Cheers
Mike
