Sign in to follow this
Whats wrong with my steering?
13 posts in this topic Last Reply
When manoeuvering in tight spaces (eg parallel parking) The steering linkage seems to stick over to one side when driving away.
For example: if im pulling out of a tight parking spot and turn the wheels all the way to the left, the car wants to veer left when driving away. It'll continue until I make a right turn, then the steering straightens out and i dont have to fight with it. The same thing and vice versa for a sharp right turn...
Occasionally when making a long turn the steering will stick and i have to jerk it back so i dont keep turning. Little scary at times!
Tires are about 33psi and all the linkage is tight...
Could it be steering box? or idler arm sticking?
thanks guys
damn cross-posters!! not-I just replied to this on assfly. steering box seals have been known to leak.... maybe a good idea to check the fluid level. Also Id put the front wheels in the air and have a buddy operate the wheel while you check for loose or whatever pieces under there. I suspect the box itself tho. the worm gear might have chunked in that position or something, too.
HTH!!
Rob
thanks for both anyway! I have a feeling the gears are messed in the box. What a shitty job though, esp with the m20 stuffed in there.
Sounds like you may have gotten some of the washers and spacers mixed up, this will cause them to bind up like you described.
mine was EXACTLY the same symptom, EXACTLY. What did it turn out to be? Loose front wheel bearings... I had that thing in for an alignment, i spent hours checking all the suspension stuff, i blamed bent rims, crappy tires, low tire pressure...etc. In the end...5 minutes to tighten the wheel bearing fixed it. I haven't put the new ones in yet..but I'll be changing them yearly from now on anyway..due to front spacers i have to use for my 'non 02 spec' offset
Matt
ps you can just BITE me for living in a province where its not currently minus 15!!!!! :) argh!!!!
atleast you have more time to work on your car. And can afford not to drive it!
I'll try the wheel bearings dude...even though they're pretty new and i check them fairly often. How tight should they be anyway?
upper spring perch
washer
strut bearing
washer
tube spacer
washer
nut
replace oil in gear box with SAE 90
check idler arm
check tierod and centerlink connections
check strut bearings
tighten wheel bearings
and maybe test between each one and let you know what solves it
later
marc
as for how tight...check the manual..its some 'tighten to this setting, turn the wheel, back off a bit' procedure. but if the car is jacked and you reef on the wheel and there is play back and forth, well..it very well could be that.
BTW, i put new ones in..don't know if i did them wrong..but they didn't even last 5000 miles (driving like a bat out of hell the entire time with 5mm spacers, mind you..)
matttttttt
