gboghosian
front suspenion woes
3 posts in this topic Last Reply
I am rebuilding my suspension with urethane bushings. With the control arm bushings in, the control arm/wishbone will not go all the way on to my radius arm/tension strut, even when the inner control arm is pushed in against the mount. With the stock rubber bushings it all fit together, but now, no such luck. Ideas? Suggestions? More pictures? TIA (Yes, I know I have no washers on the control arm bushings, they are in the mail to me)
click on picture(s) for bigger version
Slide the arm through the front of subframe and outer control arm first, then swing up the inner control arm and connect the inner control arm after the outer side is in. Makes any sense?
626-497-3773
Le
626-497-3773
Le
I just tried that and it didn't work. I have an eccentric bolt for the inner control arm mount, not a straight bolt. There isn't enough play in the bushings to do that. Thanks for the suggestion though.
gabe
