  • Announcements
    • steve k.
      Marking as SOLD   11/04/2016
      In the "For Sale" post you will se a button "Mark as Sold"  Use that to indicate that the item is no longer available.
Sign in to follow this
mikem
Parts for sale - Fort Worth, TX
5 posts in this topic Last Reply
Still have these parts to sell. Email with questions and offers mmiller2002@yahoo.com, thanks
http://s3.photobucket.com/albums/y74/mmiller2002/For%20Sale/Parts/?start=all
Part & Qty.
Exhaust downpipe + 3 bolts 1
Stock intake manifold 1
Distributor -164 1
Stock 2bbl Air Cleaner 3
Stock 1bbl Air Cleaner 1
Radiator - stock from '76 1
Jack 1
Vent window regulators - Driver 2
Vent window regulators - Pass 2
Ash tray 1
Dash top pod 1
Interior door pulls - tan driver's only
Bosch Blue Coil 1
Rear 1-dot top spring pads, pr new 1
Rear bottom spring pads, pr new 1
Steering Wheel shroud - metal 1
Stock shift knob 1
Momo shift knob 1
Wiper switch 1
JAM carb adapter 1
Glove box front panel 1
Glove box latch 1
Sommerbetreib box 1
Steel wheels from '76 5
Tail light assy, square, pr 1
Accelerator return spring 1
Pass door handles, exterior 1
Seat slider levers 2
Door lock rod grommets 9
Door lever, interior 2
Door lever, interior insert 1
Rear view mirror 1
Window handle 2
Window handle insert 1
Vent window knob 1
Misc interior switches & knobs
Weber DGV diaphram 47047-355 new 1
Weber 32/36 spacer 1/2" 1
Weber 38 spacer 1/8" + gaskets 2
Choke cable 1
Misc 32/36, 38 parts
'76 Smog Stuff
Seatbelts '76 front well used 1 pr + hw
Weber Technical introduction 95.0005.45 1
Part no. Qty Description
31331110540 4 Strut top cap
07119963300 1 Washer-intake man. Water fitting
07119963073 1 Washer-intake man. Water fitting
34321103066 1 Brake fluid warning switch
11111721614 1 fuel pump spacer
18111245500 1 Exhaust downpipe gasket
25111208580 2 shift platform mounts
64218042132 3 air cleaner mounts
No pic right now. It's just a basic pull & twist cable. It was plenty long enough when it was in my '76 for Weber 32/36 and 38 applications from the carb to the standard spot on the lower left of the steering shroud. I'll see if I can get a pic tonight. email me. thanks
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
