craaaazzy
major oil leak from front of engine
3 posts in this topic Last Reply
hey guys,
the 02 i just bought has sprung a major oil leak from the front of the engine (previous owner said it did not leak previously). from what i can tell, it is coming from the front main seal as the crank pulley has drops of oil on inner most portion. not knowing much about this motor (hayes manual is being shipped to me), how hard is it to replace this seal? is it a simple, remove crank pulley, remove and replace seal? or do i need to remove the timing cover (both upper and lower)? tia.
fred
hey guys,
the 02 i just bought has sprung a major oil leak from the front of the engine (previous owner said it did not leak previously). from what i can tell, it is coming from the front main seal as the crank pulley has drops of oil on inner most portion. not knowing much about this motor (hayes manual is being shipped to me), how hard is it to replace this seal? is it a simple, remove crank pulley, remove and replace seal? or do i need to remove the timing cover (both upper and lower)? tia. fred
This issue was recently addressed on the board. Toby suggested it might be possible to remove the seal with leaving the timing case cover installed. Unless you are a magician, you will still need to remove the crank pulley. This can be easily accomplished with a small two or three finger puller. And it will likely require removing the radiator.
Haynes and other manuals are tried and true and would suggest waiting to read the chapter on this repair rather than have others pontificate in the abstract and reinvent the process. Besides, you should review the manual, if for no other reason than to familiarize yourself with other related procedures. With an unknown engine, I might be apt to remove the cover to change the seal AND the water pump, if it questionable.
Good luck.
What he said!
Also, make sure the oil is really coming from the seal-
there are a lot of places on the front timing cover
that can leak, and even the fuel pump's a possible
culprit. So a careful cleaning and some
diagnosis first might save you some aggro.
And it's technically possible for oil to leak up the
keyway on the pulley... I suppose.
