bmcallister
Temp time switch and engine block coolant plug
3 posts in this topic Last Reply
I have two questions.
Where is the plug in the engine block to drain coolant? My Haynes manual simply states that it is on the right hand side of the engine. I can find the right side of the engine (LOL) but can't seem to find the plug.
Searched the forum but don't have a clear answer. I have a temperature time switch, located next the to coolant temp sender in the twin branch housing. What is the temp time switch for? My car originally had A/C.
Thanks.
lower right rear block under cyl 4 that looks like a bolt 17 or 19mm
I just did my coolant flush for the first time a few days ago. Its a 19mm bolt under the exhaust manifold/header depending what you got. Same side as the oil drain plug only its deeper in and somewhat higher. Hope that helps. Make sure you use Redline Water Wetter.
Joey
71 riviera 2002
98 cosmos M3 sedan
95 alpine 540i
