Sign in to follow this
gwb72tii
tii injection pump belt "tightness"
5 posts in this topic Last Reply
finishing the rebuild of my motor and i'm aligning/installing the toothed pump belt
seems like the belt is fairly loose? don't know of any adjustments to get it tighter, or does it need to be?
using a brand new oem belt btw
I dont remember any known adjustments when I changed mine. The slack should be normal
If your pump pulley teeth look like they have a "step" in them, the slack is due to pulley wear. I found a "better" used pulley when I last was into mine some years ago, but now 2002haus is offering brand new ones.
is your belt tight?
edit
tried a spare i've had for 3 yrs and it fits fine
brand new oem is out of allowed spec apparently
is your belt tight?
edit
It has some slack in it. Doesn't seem to skip teeth.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
