JackF
Vacuum gauge for tuning
4 posts in this topic Last Reply
Got thinking of this post of last week and I don't get it.
"WOW !!! I AM IMPRESSED with you using a vacuum gauge,
and 20 is a good reading - and if you adjust to the highest vacuum
reading at 800 rpm - you'll be spot on with air/fuel mixture without
having a probe/exhaust tester in the tail pipe.
Vacuum gauge is the poor man's exhaust gas tester
and your valve adjustments are set to what ?
new plugs ?
got points ? dwell is very important ."
How does one connect and manage to do this? Color me clueless...but willing to learn.
The motor is a big air pump, in and out. The better the car is tuned, the more air it pumps the more vacuum it creates.
I believe you can connect to any vacuum bung. A few guys choose a vacuum gauge as one to be in the cockpit.
You might do well to find and read the instructions that invariably come with each vacuum gauge. I Most auto repair manuals also contain detailed instructions. am confident these instructions are available on the net too.
As a hint, vacuum drawn from above the throttle plates and there is manifold vacuum. Manifold vacuum is measuring from some available port on . . . the manifold.
