Sign in to follow this
51deluxe
someone help me please
so im trying to take off one of my hubs with a hub puller and the damn thing aint budging at all so i keep tightening and tightening and tightening i before i know it my hub is completely bent and definitely not drivable so after an hour of pounding on it witha hammer and more pulling i t finally comes off there was rust holding it in place who knew so this is where u come in, I NEED A NEW HUB, i cant find an on ebay or at autohaus or at ireland anyone have a decent one forsale for a decent price. by the way its a 75 2002
You could use this opportunity to upgrade to 320i hubs and go with some vented rotors.
While the original poster did not specify, I'd wager he was struggling with a rear hub instead of front, so there would be no swapping 320i parts.
If this is correct (stuck rear hub) I'd suggest the splines on the stub axle are probably corroded as well, and you would be better off to replace both the hub & stub axle. Stub axle failures, where cracks initiate at the splines corrosion pitting, are fairly common. And the result is the rear wheel leaves the car while you're driving.
Sorry no help with spare parts for sale, but do take a close look at the splines & consider doing the complete repair with both parts.
I'm with John - 2 parts are a team here. DO NOT
replace just one of the two. The thing was seized and rusted
from over-heating, improper tightening, long term
running with poor lubrication, and neglect.
The splines on the stub axle mate very tightly
with the splines in the wheel hub. Replace just one
of the two and you'll either loose a wheel from
premature failure, or revisit the whole repair soon
because of wobbly wheelitus.
Any BMW dealer can supply you with new parts, the needed
bearing kit, and check here for the correct way to reassemble
the whole mess so you don't ruin the new bearings.
?..........or is Mr. deluxe indeed asking about the FRONT stuff ?
i have a good serviceable rear hub with good splines i can ship out today. email me
to as the hub) available. Located in Vacaville,CA.
shermanmartinez@hotmail.com
Try DOUBLE 02 SALVAGE in Hayward, CA. They probably
have a couple of them.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
