gusopenshaw
Rust on Chrome Around Rear Window
4 posts in this topic Last Reply
back window? rust? it's a plastic trim strip
in the center of the window rubber seal.
You replace the rubber seal, and the trim strip,
don't forget the trim gap piece. Address
the 'rust' that lurks under the seal from the decades
of water and fine corrosive dirt that works it's
way under the seal.
CD: I appreciate your response. Sorry if I'm slow on the uptake. By:
in the center of the window rubber seal>>
are you saying the sealing frame is a plastic piece? I'm not entire sure what is rusting?
Below are the parts from Maximillian. Are we talking about part #9?
http://www.bmwmobiletradition-online.com/bmw/showparts.do?model=2214&mospid=47140&btnr=51_3318&hg=51&fg=05
THANKS!
the plastic 'filler' trim strip which is chrome
appearing (not a metal strip that can rust - but a plastic strip with chrome fininsh that will appear to be rustiing when their very old)
is pressed into the rubber seal for the front and back windows.
Glass - rubber seal - plastic chrome trim strip
remove the old brittle rubber seal and install a new
rubber seal, and new plastic filler trim strip.
If there is any 'rusting' it occurs UNDER the rubber seal.
The body opening rots from water and decades of silt
attacking the thin body medal that the windoe/seal sits in.
THAT is what you need to worry about during any front or back window
repairs - is the rust repair before reinstalling the glass.
A photo of your condition would help
