The 2002 got a radio today!!!!
752dbl02
Finally after owning the car for a year and a half as a DD i finally have tunes!!
Just a simple deck is in it right now, connected to two KLH indoor/outdoor speakers. But i was wondering where others have mounted speakers in the front. I know you can use the hat deck and kickboard under the backseat for the rear. I think i remember reading before that there were underdash panels that people used. True?
TIA,
Chris
'75 2002
Photobucket
The original set up was a single speaker in the center console. These were monoral (sp?) radio's remember. It seems like the best way to do stereo is to mount the speakers under the dash in front so as to avoid cutting holes in the door panels.
I first owned a 2002 in 1975.
I'm in the same boat with the 72. I have a set of MB Quartz 6x9's in the hat shelf and wires run to the front but no speakers yet. I have heard that a speaker needs some backing so I'm going to fabricate a can to hold a couple small front speakers. Or, is there enough space to mount a speaker in the kickspace. I imagine I'd be kicking the cover off all the time, but has anyone done this?
I mounted a pair of coax 5" speakers (4x6s will fit too) on the cowl sides up under the dashboard. These were flush mount speaker kits, so I made housings with a piece of 2x6 (you may need two thicknesses if the speakers are deep) and a band saw, then covered the wood with black vinyl upholstery material.
The wood mounts are screwed into the cowl sides through the carpet, and the speakers fastened to the wood. The whole setup can be removed without leaving any visible holes, and give much better sound than mounting 'em on the cardboard underdash panels.
When positioning, make sure the driver's side speaker mount will clear the hood release lever.
cheers
