JAS
Shifter Rebuild Question
6 posts in this topic Last Reply
The upper part of my shift level is quite floppy, while the shift linkage itself is quite solild (been under the car and checked). Is it possible to remove the upper part of the shift lever from the lower part without removing the entire shift lever assembly from the car? Want to gain access to parts 12 - 20.
Thanks
John
Most parts can be accessed from above the trans. tunnel. The lower delrin bushing and possibly some washers is below the car.
The (2) rubber pieces that secure the upper shifter to the shaft are tough to get back on, so you might as well remove the entire unit.
Thanks Jim - pictures are a great help. How did you separate the upper and lower portions of the shift lever?
John
There is a snap ring in a groove that holds the two pieces together. Remove the ring, then grab the outer piece and pull upward with all your might! Don't hit yourself in the chin when it pops loose.
One thing I didn't think of is to put a screwdriver thru the round bottom hole and step on it with both feet while pulling on the upper piece.
The new rubber bushings are really tight, so you'll have to use a rubber mallet to force the upper piece over the shift rod.
Sounds like I should remove the whole assembly to make my life a bit easier, especially when pulling the pieces apart and putting them back together with new parts.
Thanks again.
Good idea. That's what I did. If you are "going under", you might as well replace the shift tower mounts and anything else that looks old and worn out.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
