2002Monster 2 April 19, 2009 Okay, so I've looked through the search and found that for 1974, the headlights do not come on when the key is out of the ignition....you can pull the switch and only the parking lights come on....perfect.... Okay, so when I turn the key, fuses #9, 10 and 11 should be electrified/hot and I should be able to get a voltage on my voltmeter by touching the prongs on the fuse and to the ground...... I get nothing on fuses 9, 10 or 11 when the key is turned to "run"... My headlights do not work and all of the relays are new....I pull the switch and I can hear the relay click, but no headlights.... I'm also not getting any voltage to my +ve side of the coil.... Please understand that I hand assembled the whole car, and I put everything back together..... The only conclusion I can draw is that I quite possibly could have mixed up the multiple wires that go the steering column and connect to the ignition switch....but I used a surrogate ignition switch to make sure I was putting the wires back correctly. When the battery is connected and the key is out of the ignition, the red chargin light is illuminated....when I turn the key to the first position, the red charging light goes out....when I turn the key to the next position, the horn, wipers, cluster lights, gas gauge, heater blower, etc, work correctly....then I can turn the key once more and the engine turns over.... The car doesn't start, and while everything is on, I check fuse #9, 10 and 11, and there is no voltage.... Would anybody like to take a nice trip to the great state of Michigan and help me fix my electrical gremlins? or better yet, provide me with a picture/schematic of the ignition switch prongs and what wire goes where? Thanks....sorry for being such a long post. 02Monster Share this post Link to post Share on other sites
BillWilliams 125 April 19, 2009 Look back about five days to a post from ship_8. he posted an excellent diagram of the starter switch and the wires Share this post Link to post Share on other sites
BillWilliams 125 April 19, 2009 http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,321368/ Share this post Link to post Share on other sites
Guest Anonymous April 19, 2009 Looks like you have two wires switched. Term 15 should have the green wires, term R should have a black wire. Share this post Link to post Share on other sites
