Sign in to follow this
boldtu
Brakes pulling
2 posts in this topic Last Reply
I did a forum search and could not find what I needed
I disconnected the brakes to get the shock cylinders off for repair
After I did this I blead all off the brakes
Pass rear
Drive rear
Pass front
Drive front
I used a Mighty vac
I got a good seal around the bleeder valves but kept getting air after bleeding for a few minutes each on all four brakes
Now the car pulls to the right during braking
Which is the side that I dissconnected
Could this be a leek?
Bad brake booster line?
Bad master cylinder?
Thanks in advance guys
Chet
If everything was fine with braking before you replaced the strut inserts, then it is likely there is air in the system. Usually the pedal is soft w/ air, though.
I would rec a rebleed.
There is the possibility you need to rebuild your calipers too. Is the rest of your suspension fine, eg, ball joints. Are your brake hoses original? They can fail internally and cause poor release of hydraulic pressure on the affected side.
Bubbles during bleeding can be from cavitation too.
Good luck and let us know what happens.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
