Sign in to follow this
Also How do I replace the sway bar bushings on the subframe?
3 posts in this topic Last Reply
The ones that are not the endlinks, buthold the bar above the front of the subframe. I missing the pass. side one and it hits everytime i hit a bump.
Thanks
Andy
There is a metal half-cylinder (basically a hump that goes around the swaybar) that holds the bushing in place. It is held on by two bolts; I think you'll need an allen wrench to get them off. It should be pretty self-explanatory once you get under there. (I think I'm remembering that correctly)
Yeah, what ben said. If you're missing the metal hold down strap thingy, it may be hard to understand. If you're just missing the right side, look at the left one. Or you could look at the rear bushings and how they are held on, I believe they are the same.
