Sign in to follow this
Vacuum advance dizzy?
4 posts in this topic Last Reply
URL: http://www.classicautosalvage.com/~lfloden/
Where does the vacuum tube from the distributor connect on the engine? Is it one of those on the intake manifold? If so, what is the other one on the intake manifold for, do I need to plug it?
I wish I had a picture to show you what I mean.
The vac advance line connects to the upper vac port on the carb (Weber). The lower one was plugged. These two ports are near each other on the passenger side of the carb just above the mounting flange as I recall.
Let me know if you need more info-
(At lest that is how my car looks...)
kevin
'73 2002
I did....
Kevin
