Sign in to follow this
Suggestions for fixing a window regulator?
4 posts in this topic Last Reply
Without buying a new one that is. The pin that holds the regulator arm in the window support track is gone. The regulator arm just pops out when you try to rull up the window. Anyone know of a fix without buying a whole new reg....?
Actually, isn't there a plastic wheel on the pin? When those go, I've found that you can scrounge one from a newer junkyard car (don't remember which) and bolt it on as a replacement, staking the bolt so it won't unscrew......
Last I looked, the wheel wasn't available separately...
hth
Yeah I knwo not exactly the best way but heyim cheap. Just took a cble tie and ran it around the track the regulator runs in. Works like new. Cost a hole $.05. And I have 49 more to use to fix it!
Andy Rattley
1971 2002
the spring hooks into, e-mail me--I have a fix...
Mike
